2 Attachment(s)
LQ4 stroker idle problems
I'm looking for advice getting a stable idle. The engine starts when cold (not smoothly, but it doesn't die). Around 80-90*F ECT the motor dies everytime. at that point it will only restart with some pedal and will die as soon as you let off the pedal.
Engine is 403ci w/ new heads and 236/244 cam, 102mm TB DBC.
I am attempting to tune SD - I have the MAF failed.
I've messed around with spark and Fuel quite a bit and haven't had any luck. I don't fully understand the ETC area scalar value, mine is the decimal version (stock value .0255) - I have tried moving it both up and down and neither one really seemed to change anything. I've also messed with the injector timing, it seems a little better where It's at right now but it still dies at the same ECT.
I am running out of ideas to try on this one. any help would be appreciated.
Attachment 127664Attachment 127665
