Engine fails to run in speed density
2000 Camaro with LQ9, L92 heads, 641/615 231/236 112 cam, LS3 intake, rails, and injectors, nick williams 92mm tb, 1-7/8 lt, dual 3 inch.
After loading in injector data, car starts, runs and idles on a stock ls1 tune with MAF hooked up. Wideband is hooked up and working. Set MAF to fail, along with disabling fuel trims in preparation to tune VE tables in SD. Car will fire but immediately dies. Tried bumping idle settings and VE tables around with no change. I've been looking through different tuning guides and searching the forums, but have not found anything yet that will make this car run in SD. As soon as you turn the MAF back on, it starts right up. Any input on this would be greatly appreciated. I've attached the tune files I'm using. Thanks.
