Originally Posted by
BPella
Something you may need to find out is with a 2020 Silverado, it may have the new ECM which requires removal and unlocking to change the tune. I have a 2019 Silverado LD which has the 2018 PCM which isn't locked. Before you go Whipple, you need to verify you can change the tune (write) with HP tuners. You may be able to read the ECM but you may not be able to write to it. This also may apply to the transmission module (TCM). I am not sure but others in the group should be able to verify. Good luck. All I have done is disable DOD until I get my wide band purchased and setup.
