Just got my PLX M-300 and I'm wondering about hookup. It has only 1 ground for use with 12 v power supply. Do I need a ground to use with the analog output to the EIO? Do I split the power ground? Thanks,
i had the same question when i installed mine. The guys @ plx told me that the output is grounded through the unit. all you need to do is hook the output up to the correct input on the EIO interface. I believe it is pin3 but you can find the correct info in the help file
