2 Attachment(s)
Mopar R3/W7 small block - Bosch injectors
Hello,
I am assembling a small block Mopar (393") which will use some old LeMans injector castings. I want to use a Bosch injector and am having a hard time understanding Bosch's technical data. On some of their injectors, the spray exits the nozzle at an angle...this is not the spray angle itself but the 'tip' of the spray pattern.
This is represented by Bosch in their technical literature using a Greek lambda symbol. On the injector I am considering (0280158187) there is a 10 degree tip...but the direction of that tip is not clear to me.
Does anyone know which way the tip occurs? Is it toward the electrical connector, or away from it? Thanks.
Attachment 141353Attachment 141354
