Working on a twin turbo gen3 coyote. What is the hp (or lbs/min) limit of a 3” charge pipe? 3.5”?
3.5" and 1600+ whp zero issue
Quote: Originally Posted by small tuner 3.5" and 1600+ whp zero issue Not in the lifetime with a stock MAF...
Quote: Originally Posted by 61unicoyote Working on a twin turbo gen3 coyote. What is the hp (or lbs/min) limit of a 3” charge pipe? 3.5”? 3.5" around 14psi with stock MAF, might go below period 80 which is not what sensor likes. It will work below but not stable.
Quote: Originally Posted by veeefour 3.5" around 14psi with stock MAF, might go below period 80 which is not what sensor likes. It will work below but not stable. Thanks much….that’s what I was needing ( stock maf and period limit). Thanks!
