Whats up everyone, im working on a tune for an 01 ram with the 5.9. Im curious what everyones done with timing on these. through a little research on the forums ive read that theres a little bit of power to be had by adding some timing up top but when i pulled the factory tune from the truck i saw that it was already at 40 degrees which seems like a lot to me. i also noticed the torque management in the ecu pulls 7.5-15 degrees of timing out over 4k rpm depending on gear.
will just getting rid of torque management give me what i want or will it still be too much timing.
Any suggestions on what would help make the truck run a little better would be appreciated.
attached is the stock tuneAttachment 98507
