Questions for Greg/ EFICALIBRATOR about the tuning disc for current owners.
Just thought we could ask Greg some questions in this post so its in one place.
Rather than pming him and then he will only have to answer them once. They could even maybe make this a sticky.
First question.
I can't seem to get my data disc to load up.Is it a dud? I dont have microsoft office on my home pc. I got this freeware open office but again can't seem to even get the data disc to load into it. Something I am doing wrong. I put the data disc into my drive and nothing seems to happen. Haven't tried it on my laptop yet.
Next min pulsewidth is listed. Do I set default pulsewidth the same as the listed minimum pulsewidth? my car has default and minimum.
Next question. Heard that if I have a boost referenced fuel regulator that use same values across the voltage offset table just like in the ifr table.
My car is 99 trans am with 2002 OS.
Another question..in the dvd you said it would help driveabilty to dial in the ve tables at the ranges where you are crusing around and think idling. But if the car is in closed loop and within the range of the engine to self adjust how can it make a difference? I can see spark making a difference to say surging problem but how can fueling if the engine is in closed loop and compensating?
Also anyway you could show short video with normal wideband or yours set to normal afr instead of lambda and how you do the corrections. Realize its similar but most of us don' have a lamba wideband.
Will likely have some more questions will mark them down and post them after going thru the dvd again .
