1 Attachment(s)
3 bar enhancement now won't rev over 1800rpm
Here's the rundown of the car:
68 firebird
stock 2003 5.3 with a 99 Silverado ecm
ls1 intake w/ aftermarket fuel rails and boost reference regulator
42lb injectors
76mm turbo
We just got this car running and it ran fine before I did the 3 bar enhancement. Now the issue is that it will not rev over 1800 rpm or whenever you crack the throttle, just goes lean. I've tried to add 30% more fuel where I see it go lean on the VE but it isn't helping. I also see in the log that its commanding 12.xx afr in some of the areas when I do try to rev it. I attached the tune. I would have attached a log but I must not have saved it before coming home. I'll post one later today.
The car is able to pull in and out of the shop but I'm ready to hear this thing scream. Any help would be appreciated.
