Crown Victoria Manual Swap Tune
Hi yall, I was wondering if anyone had successfully pulled off a manual crown victoria tune with hptuners. I'm currently rockin with the 2009 p71 crown vic. Everyone uses sct with marty's speedshop, but I hate having to use mail order tunes and am determined to find around it. I was originally going to mess with a 2003 mustang gt tune because it has the same tr3650 transmission I'm using with the same 4.6 as the crown vic. I realized that the ecm for the mustang was an EEC-V, and the crown vic used a spanish oak 1024k ecm. I don't know if it's feesible to use the 2003 gt tune because of the discrepancy. I did some more digging, and the 2005 mustang gt has the same Spanish oak ecm. So in that case, would it be possible to adjust the 05 gt tune to make it look like the crown vic tune? Hoping someone has pulled something like this off, or can at least give advice.
If this isn't possible, then would it just be better to mess with the current crown vic tune, run the transmission sensor in neutral and put resistors into the old transmission connector to mimic the internal harness? I found the transmission pinout and resistance values of most of the sensors and solenoids. Only value I need to find is the trans fluid temp sensor when it's at operating temperature.
