1 Attachment(s)
wrangler 2016 3.6L gpec2 sprintex supercharged need help after replace injectors
so got a client that come with sprintex supercharge second hand installed on his car with stock injectors
after close look on couple of sprintex installs get it work with stock injectors with not a big problem
but of Corse with no injectors ther is no more fuel with no more fuel no HP ..
after i explained him that i told him to talk with customer support if sprintex and order a feet injectors that will be good with the sprintex and known by them to do the tuning
that was the part when all go messy after first 1000cc injectors that was really to much he come again and now with 730cc injectors
bosch 0280158290
Flow Rate: 731cc/min = 500g/min = 66lb/hr @ 3bar
Spray Pattern: Single cone spray
Configuration: Compact body length
Nozzle: Regular tip nozzle
Resistance: 12.0 Ohms
Connector Type: USCAR
after a lot of search i found the deadtime of that injectors but i don't get the ideas with that controller.
ther is inj PW vs Fuel mass and Fuel Mass vs Inj PW that suppose to be changed mirrored
and inj pw offset that need to be calculated by deadtime (did not know how to calculate it ther )
i attached the sprintex tune with stock injectors here and a pic with deadtime specs of that injectors
really need some help here friends that injectors suppose to work but anything i try so far just lean/rich mixture i get and a rough idle..
will be glad if someone can explain how to calculate and feet that 730cc injectors with 66lb on 3 bar to 4 bar wrangler 3.6L to run it
link for deadtime pic with details
https://mega.nz/file/fk4gXLQR#cQB0Q0...Gd3DmlOcoxip-Q
