x7F Negative Response Code
Problem
The x7f Negative Response Code generally indicates an issue with the communications in the vehicle.
Resolution
| 1. | If you have the ability, we would first suggest using a bench harness to read or flash the module in the vehicle. |
| 2. | If you do not have the ability to use a bench harness or the problem persists, start a support ticket and send us the following: |
| ■ | A debug.dat file from your PC. |
| ■ | A VCM Suite Infolog while connected to the vehicle. |
